Wifi Disconected
sarahm
I have a Samsung Galaxy S from AT&T, for a while now i have a problem with a few WiFi connections, my old work, my husbands work, and now just recently my house.
The WiFi constantly tries to connect to the router, then right away disconnects. I am using a static IP, and I have tried resetting the router. This problem started at home after i moved my entertainment set up along with the router, so everything was disconnected.
As for the WiFi at both job locations I just cant figure it out.
Go into settings
Go to wireless and network settings
turn on airplane mode
turn the phone completely off
turn phone back on
go into settings
disable airplane mode
go to wifi settings and turn it on
WORKS EVERY TIME!!! From AT&T Tech support guy stating it's a hard kick to it and it gives it that extra boost.
