Solangeburgas
Member
My "app ower monitor" was off long time ago, no problem with battery at all since then. Often this monitor become too aggresive making more bad than good. But with this set to off my wifi still disconnects...
So far, so good. This has worked for me for more than an hour.Hi
I've been having this extremely annoying condition too, since the last software update.
I came to the conclusion that it was some kind of aggressive power management setting that was putting all kinds of apps to sleep.
Today.... I think I might have found a solution... I say might, as it's only been a few hours..
So I've done is this..
Go to settings.
Search for "Battery"
Click on the three menu dots in the top right hand corner.
Click on "Advanced Settings"
Turn off "App Power Monitor"
So far, so good.
My WiFi stays connected and the 2 VoIP apps and Text-to-voice app are alive and well.
Curiously, my battery drain doesn't seem affected.
I'd be interested to know if this solution works for other people.
Good luck.
Yes it's in a case but just weird that this has only been an issue since update a few weeks ago.
Was the update from Android 6 (Marshmallow) to 7 (Nougat)> or was it just a security patch? If the former, it's always a good idea to do a factory reset after a major version upgrade (after backing up everything).
I was experiencing that exact same symptom about a week ago but then for a different issue I did a master reset..now I don't see it happening any more..i don't think is an update that caused it because I haven't done any up date..i don't do updates..I'm still in 5.0..
Am I hitting it by the right angle??
I'm still having issue. After reset and losing everything.
