I got an S4 and put the Stock Android on it 4.3. I wanted to create a wifi hotspot and I am able to do so. I try to connect with my Laptop or Tablet and it does (I get an IP). I cannot access the internet. Am I missing something?
Some carriers restrict your ability to tether unless you have a certain data package. Are you sure you have the right data package or an appropriate work around if you don't?
The issue was solved. I had 2 APN settings and when I deleted the APN setting that was not used by the phone to get internet access everything worked fine.
