K kuobob Member Feb 1, 2011 #1 Is there a way to set up a wifi hotspot by using the internet of a computer(like using a usb connection)?
K kuobob Member Feb 1, 2011 #3 yeah. I want to be able to set up wifi when theres no wifi but internet from a pc
LECTER Android Expert Feb 1, 2011 #4 kuobob said: yeah. I want to be able to set up wifi when theres no wifi but internet from a pc Click to expand... Only way I see is by getting a router.
A AceMathias Well-Known Member Feb 1, 2011 #5 can't you just use the wifi hotspot app on 2.2 and just make use of your data connection, works well for me?
S stevo25 Lurker Feb 1, 2011 #6 if i understand you this may help http://androidforums.com/htc-desire/89237-reverse-teethering.html#post846727
