roadkill42
Android Expert
Once you are successfully rooted do the following and don't deviate from what I say here:
1. Download the latest Treve WIFI APK - here
2. You need to open the Wifi app, DO NOT START tethering or click the wifi symbol AT ALL on the initial launch. First, context/menu click to get the menu up, go to settings and set the settings to the following. You MUST set the FIRST setting I put here at the top of the list FIRST. You WONT see a couple of these options in the settings menu UNLESS you set the device-profile FIRST!!!!!!!!!
Device-Profile - Generic ICS/JB wlan0 AGAIN SET THIS FIRST
Setup Method - Auto
Fallback Tether - YES
Send Netd Max Client - YES
Enable Wifi encryption - YES
WiFi Driver Reload - YES
(don't check the second one though)
Keep Alive / Connection Check - YES
MSS Clamping - YES
Routing fix - YES
Exit settings, then turn the hotspot on for the first time. It will install the binaries and config, and should start for you without any errors. By default the app gives your hotspot an SSID AndroidTether and pw of abcdefghijklm.
Let me know how this works guys. sorry the link not workinv
Setup Method - Auto
MSS Clamping - YES
Routing fix - YES
