willywonkaisrsh
First, please don
Have you tried other wifi connections other than you home?
Same results?
Try changing the kernel sometimes the phone can be picking with which one you are using. I went through 7 or 8 to get the one that works best for my phone.
I dont think I even know of 7-8 kernel's.
Here is the link to them.
P3 P3Droid Kernels
ChevyNo1 Index of /froyo/kernels2
Index of /froyo/kernels3
Slayher Froyo Kernels by slayher - CyanogenMod Forum
I have been using the slayer 1200 version 1.6 and it seems to work great.
Just found this thread. http://androidforums.com/droid-all-things-root/98988-froyo-kernels.html
I just want to make sure before I try a bunch of different kernels...
Your saying that you had the same probelms with wifi on your Droid 1 (connection, signal, and speed) and after trying a bunch of different kernels, you finally found one that fixed all of the wifi problems? Now your wifi works with absolutly no problems with Slayer 1200 1.6?
I was having the same issues. It is a know problem with some of the kernels. The slayer kernel is working great for me, other have had good luck with the chevy kernels.
Try a different chevy kernel then you have, they are supposed to have ipv6 support. The one's from kernel 3 page are suppose to have fixed the wifi issue also.
Have you thought about switching rom's. I use charity smoked glass. http://androidforums.com/droid-roms...ass-themed-version-11-froyo-2-2-1-frg83d.html
