Help WiFi Issues after ICS Update
artbytes
Is anyone else having problems with their WIFI after the ICS update? My tab seems to be losing the connection and is loading Web pages really slowly. My computer using the same WIFI isn't having any problems - just the Tab. I've found that if I turn off the WIFI, and then turn it back on again, so that a new connection is created, it perks up a bit - for awhile.
Ugh. I don't want to believe this is happening. It's very frustrating trying to get much done at times. It's just so slow to load content from the Web.
No problems here either, but I did a factory reset on mine to wipe it clean which may explain why there are no issues.
I'd suggest that first you 'forget' the WiFi connection on your Tab, power cycle the WiFi router, then connect to your router with your Tab again. That may fix the issue. If not, you may need to do a factory reset to clear the problem.
Thanks. I tried that. It's probably a little too early to tell, but it seems to be working better. Keep your fingers crossed.
My wifi connection seems to be sketchy after the ICS update as well. I haven't tried a factory reset yet, but did try the "forget" option but it doesn't seem to have helped. If the factory reset does indeed solve your issues please post.
No problems here.
I did the update from HC 3.2 to ICS again yesterday.
I had done it through Kies and everything was fine. I then rooted so as to edit a file.
I did something wrong (note to self-don't rely on 63 year old memory :() and had to wipe in recovery, etc., flashed back to HC, then did the ICS update via OTA.
I swear that my tab is even faster than it was before. It's now 3:15 pm here, and I've been
using my tab since about 10 am. Everything is running like a rocket.
Like bfksc, I do a reset when doing updates like this, so my updating yesterday involved 3 resets.
After the resets, I did not do any updating of apps, or re-installing my apps, etc.
All I do is basic setup to get the tab running. After the update to ICS on a clean install of HC, I then updated the apps installed with the OS, installed my apps, set up my home screen, etc.
Also like bfksc, I'm a firm believer in this method when doing major updates.
I really don't mind the work involved; kind of fun.
I should add that I don't store anything on my tab that's really important. Only about a dozen photos that I use for fun with Photoshop Touch and a couple of other apps. They're on my PC, so getting them back to the tab takes a minute or two.
All I can say is that I'm having no issues here. Everything is working great.
For those of you having issues, another recommendation from here to try the reset.
Make sure you backup/save anything important.
Good luck, and have fun.
I've been traveling and had a chance to test out my tab's wifi connection on a few different networks. The good news is that I've had no wifi issues at all on any networks while traveling. The bad news is that I had problems again upon returning home. I think it's safe to say that my tab is just fine. Now I've just got to figure out why the Internet connection on my home network is so flaky. It's started to effect my laptop, too. So at least it's not an issue with ICS and my tab.
I flashed mine with the UK rom the week before it his the US and if anything my wifi is better. with HC i had spotty wifi at work, i could be 3' from the router and still only get 1 bar on wifi. now ias i type this i am 20' away and have 3 bars. better and faster connection overall imho
To help (not really, as it turns out) with the diagnostic: my TAB (GT-P7500D) on ICS OTA is just as good as it was on the original HC 3.1. (In fact mostly nearly as good / often better than 5 other devices I run, alternating on two WIFI, here. (And BTW, HSPA+ remains "right on the numbers.") 0
Full disclosure: I did a factory reset for the OTA.
Is anyone else having problems with their WIFI after the ICS update? My tab seems to be losing the connection and is loading.
I am having the same problem with my 7510 Wi-fi tab (Canada), after the upgrade, it doesn't keep it's wi-fi connection. Everything else on our network is fine. Just the Tablet has issues, and only since the ICS upgrade. There are 5 other wireless users on our network, Mac and PCs, no one else has issues, and this was never an issue on Honeycomb.
I am running ICS on a Galaxy 3, and there is no problem there.
As mentioned,
So by habit now, the second I pick up the tablet, I disconnect and re-connect. Despite the fact that this solves my issue, I wonder if there is a fix for this?
Anyone?
Is anyone else having problems with their WIFI after the ICS update? My tab seems to be losing the connection. My computer using the same WIFI isn't having any problems - just the Tab. I've found that if I turn off the WIFI, and then turn it back on again, so that a new connection is created, it perks up a bit - for awhile.
I have exactly the same problem with my tab AFTER the update. i have 20 devices on my router and all work perfect. even the tab stayed online before the ICS update. nothing else has changed. :confused:
Did you do a factory reset after installing ICS, or just update?
Hey all,
I am in the exact same boat.
Pre-ICS Update = wifi worked great, no connection issues at home or other places
After ICS Update = wifi cuts in/out at home/barely works, but fine when I go to work and other places
GT-P7500R on Rogers network in Canada
HELP!
No. In fact that is something else I feel is odd with the Galaxy Tab.
I always checked for updates and it never found any. Then one day I installed that stupid Kies program for some reason, and it said there was an update (which I assumed was to Kies), and THAT is what updated my Tab! Even now I check for updates on the Tab and it always says there are none. Maybe that is true, but I would expect there are some updates here and there no?
I'm not wanting to do a factory reset if I can help it as it will mess up all my icons on my screens and widgets and all my data and basically be more of a PITA. :mad: Plus, I read in this thread or another one here that a guy tried it and it had no difference -- and that would really piss me off if I went through all that trouble for nothing.
Actually, no. Instead of doing several little updates here and there, Samsung incorporates all updates into one larger version update. It's easier for them since they need to overlay the OS with their own UI. And since you've updated to the latest available version, checking for an update is a waste of time since you're already updated.
Ok...
Did you solve this situation ? I now have exact same situation after upgrade. Pls inform me if you fixed this. thanks
Hey all,
HELP!
I am continuing to have a small problem. It doesn't seem to be as bad, but maybe that's because I recognize it and deal with it quickly. Now, it's just when I haven't used it in awhile. I pick it up and can't reach an Internet site. Now I just turn the wifi off and then on. That Resets the connection with the router and all continues well until the end of my session. I never did a factory reset.
I am having a problem as well, but mine is a little different. Everytime my Galaxy Note 10.1 connects to my home wifi, it crashes the router. I can turn off wifi on the tablet and unplug/re-plug in the router and everyone in the house has no problem. As soon as I try to connect again, the router crashes and everyone loses. All worked fine until I updated the tablet a couple of days ago.
