Wifi Issues
Brandon15
I been trying to connect to my Wi-Fi but all it says is 'Saved' and no its not the password because I put a random password and it did the same thing. Ik I'm typing the right password unless somebody in my house change it which they didn't cause I can connect it on my other device. Help
Clear data and cache for your Wi-Fi app in the settings.
How do I reset it?
Try just disconnecting the power, leave for about 30 seconds or so, and then connecting again. That should reboot it. It maybe only acting funky, could be its DHCP pool is messed up or something. If the router can't allocate a device an IP address, it won't connect and so you see ”Saved” on the device.
