1
1764
Guest
I've started having issues recently with my Moto X (first gen, running 4.4.4).
I notice that I'm no longer connected to my WiFi, so go into WiFi list, where I am unable to connect to the router or rescan. I can remove or re-add the connection if it's there, but it will not actually connect (goes straight to "saved"). Sometimes after going to or coming home from work the list of connections will not have updated at all. I keep having to reset my WiFi by going into and out of airplane mode, which will fix it until it happens again. All my WiFi settings are unchanged from the defaults.
Do any of you have any suggestions?
