Help Wifi not connecting.
bundy26
I don't know what the problem is or how to solve it, everything was ok but about 2 weeks ago I can't use the wifi, says obtaining IP address , it disconnects and does the same thing over again :mad:, if someone knows the solution I'll be grateful , thanks.
Welcome to AF! :)
It would help a great deal if I knew which device you're having an issue with.
However, you could try forgetting the connection, then re-entering it's details.
Maybe you could download "wi-fi analyzer from the market and see if that gives you any ideas. Other than that...?
