Help WiFi not connecting
galaxyone
My wifi will not connect to internet via home router or elsewhere.
Turned wifi on/off, no joy.
Used code to reinstall driver, no joy.
Using 3G is fine to connect is fine, the only way I can use wifi is to turn off phone and restart.
Works fine for a short time then turns itself off, then have restart phone again.
Any clues to rectify.
check your wifi sleep policy in wifi advance settings.
try setting a manual static ip address on your phone if you still have problems.
this issue is already discusses in detail here, please search the forum.
