Apps Wifi Not Enabled on HTC Desire
mist3r0
Hello boys,
I'm a beginner android programmer.
In my application I want active wifi, but I've a problem when test my application on my HTC DESIRE.
This is The code that I've write:
Code:
if(cur.getString().equals("false"))
            if((wifiManager.getWifiState() != WifiManager.WIFI_STATE_DISABLED) && wifiManager.isWifiEnabled())
                 wifiManager.setWifiEnabled(false);
        else if(cur.getString().equals("true"))
               if((wifiManager.getWifiState() != WifiManager.WIFI_STATE_ENABLED) && !wifiManager.isWifiEnabled())
                 wifiManager.setWifiEnabled(true);
The problem is that, if the Wifi is enabled my application turn off the wifi, but don't work if the wifi is disabled and I want enable.
NOTE: I've insert this permission in the manifest file
Code:
<uses-permission android:name="android.permission.ACCESS_WIFI_STATE"></uses-permission>
    <uses-permission android:name="android.permission.CHANGE_WIFI_STATE"></uses-permission>
    <uses-permission android:name="android.permission.WAKE_LOCK"></uses-permission>
    <uses-permission android:name="android.permission.UPDATE_DEVICE_STATS"></uses-permission>
Why the Wifi not enabled?? Is a problem of Sense Interface? Can you help me?:confused::confused::confused:
You should get used to adding brackets to your if statements.
As your indentation already indicates, your else if clause belongs to the inner if clause.
Try
Code:
if(cur.getString().equals("false")) {
else if(cur.getString().equals("true")) {
instead.
Oh Thanks!!! :) This is a big mistake!!! :(
I've another question for you:
There is a method to directly enable gps without run this intent:
Code:
Intent in = new Intent(android.provider.Settings.ACTION_LOCATION_SOURCE_SETTINGS);
startActivity(in);
because thisi ntent bring me into setting menu and I do not want this!
