Help wifi not working anymore
xacto
Member
Did a factory reset, connected to wifi just fine, but it's not really working like it did before the reset, it will not connect me messenger or flipboard or currents, anything. Did not make any changes to router or phone settings. It worked before, but not after reset.
Any ideas? Am on JB, not rooted.
So it's connected but some APP's are not work is that right? Did you download the APPS ovr WiFi? I would try another WiFi and see if you have the same results.
I can download my apps over wifi, but only that, I cannot use them, browser pages are not working, cannot connect in mess or flipboard, facebook. And this wifi worked just fine before the reset... I used the backup I made with kies... maybe I should do one more, reset and not use that backup?
