I have a rooted Desire, which I've been running Pinky's ROM 1.8 for a few months now with no WIFI issues. The phone was originally locked to Orange.
I wanted to clean the phone up a bit and reclaim some memory, so I performed a factory reset and cleared memory. After that, I couldnt connect to any of the WFI routers that I've been using. The phone would always request an IP address, but then would appear to timeout.
I thought it maybe a problem with the Pinky ROM so I reflashed with the latest LeeDroid and had exactly the some problem. Its not a problem with the router. I've tried many routers, all of which used to work fine with my phone, and they havent changed. Its a phone issue. If I use a static address, then the phone reports that its connected to the WIFI, but this isnt a proper solution 'cos they are DHCP routers and dont have any static address ranges.
I've not taken any OTA updates
Any thoughts?
Nibblets
Any thoughts?
Nibblets
