nb_mitch
I gave up trying to update to 2.1 a week ago and figured I would just live with it for awhile. The device has been working great, no complaints until yesterday.
I did notice a few days ago when I left my home wifi, when I got back home it didn't automatically re-connect. But it manually reconnected as soon as I started the auto-dect up.
But yesterday it wouldn't connect. It lost my WEP password too. I an using an app called Wefi Connect (have been since day 1) and now it is just stuck in a loop and doesn't connect to my wifi at all.
This is a deal breaker, because I can't afford to stay on a 3G network while I am at home, it will kill my 200MB cap and I haven't figured out how to turn off the 3G either.
TIA
ps, I did try to flash to 2.1 again last night hoping it would fix it. I am just having no luck, first when I down the files into seperate folders and then Extract the files into seperate folders I get some "Can't extract history files" error. But then when I go through the process every seems to work ok until after 3 minutes into the flashing and then I get an error that says it can't find the loader.sin but says it was successful. But my device is unchanged, still branded to at&t and still on 1.6.
TIA
