The past 2 mornigns i've woken to find my S3 is running on 3g instead of wifi. When I look at wifi I find its on, but my remmbered network "XYZ network" says 'disabled' under it. If I tap on that network like I wanted to connect to it it connects right up and is fine. I've checked my settings: its not set to disconnect at sleep. I've toggled the setting off and on this mornging to see if it makes a difference - I'll be able to report on that tommorow AM.
I can't find many explanations of what this 'disabled' means. My wifi signal where i plug is is low but it seems to stay connected if i use the wifi.
Thoughts? Ideas? How does one troubleshoot this?
