Help WiFi Problem Galaxy S
Allshare solution works like a dream.. Thank you
I Tried to connect my galaxy s thru allshare, even it didn't work...
My ph used to work perfectly on wifi but now for some it just dont work.. All i get is an error "No connection" Even though my ph is connected to wifi.. :@
I've tried all the suggestions on here and nothing worked. Allshare worked for about 30sec. Wi fi worked fine for the first 4 weeks went away for a week,then nothing. Does not even pick up my home wifi when sitting next to it. Wifi is working because everything else has excellent signal strength. Any new ideas this driving me crazy.
Hi All,
I too have problems with my home WiFi but, before reading this, was blaming it on my home Wifi Router.
Out of curiosity, what is the make and model of your home WiFi routers?
Mine is a Belkin G+ MIMO (F5D9230uk4 Version: v3000)
Thanks..P
I also have a Belkin wireless router. The wireless on my Samsung Galaxy S stopped working as well. The first time I did a factory reset and it worked after that but a few months later the same thing happened. What I ended up doing this time was change the SSID name AND the SSID password in my Belkin router. I then rebooted the Belkin router from within the interface and then I had my phone detect my Belkin router, typed in the new SSID password and my phone was able to access my home wifi. Hope this helps.
I am using a Samsung galaxy S very newly purchased and i am facing issues in the WIFI. The wifi gets connected for a second or so and then disconnects automatically, i have tried to check out every problem in the wifi and modem but no solution yet. This phone never connects to any wifi networks. i had deposited it to the customer care unit, they returned it back with out any solution and they say its okay.
Hello guys, i have one question related to Wi:fi on Galaxy S. The signal on my phone is very poor, so is there anyone who can help me to solve this problem.
Sincerely,
Hani
hi all
i have purchased samsung galaxy s but i having issues in home wifi.
whenever i connects through wi fi, signal appears on mobile and it shows connected but i am not able to open website as it shows server unavailable.
I have asked to samsung service centre and they have formatted my phone but the same problem exists. I have laptop and nokia E5 that connects on first attempt on home wi fi.
So pls suggest what to do.
IS there is problem in my mobile or in wi fi router.
regards
mahak passi
Hi everybody,
I have a problem with the wifi connection on my Samsung Galaxy S as well. Since a few weeks, when I try to activate wifi connections, it says it is impossible to find any network (although there are plenty active in my office and it worked before), then wifi is automatically off in a few seconds (before, if activated, it would stay like that until I would turn it off)
Any idea on how to solve this issue?
