wifi problem.. plz help
kash13
i'm using this galaxy grand quattro , when i choose wifi for internet.. it connects easily but i can't access internet from the device. i'm using laptop and internet works fine. :confused: please help
Is this just happening one WiFi router, or any that you try? If it's just the one, try resetting the router, that can sometimes resolve connectivity issues.
i tried wifi only at my home.. when i bought this mobile internet access with wifi was easy for few days bt now :confused::confused::confused::confused:
reset didn't wrk :confused:
Hi Kash13, I too got the same problem. My Quattro wifi and Internet were working fine for the first 2 days of the purchase. Now It says that it connected to Wifi but no Internet on Mobile. Did you get any resolution? Thanks.
