Crackity Jones
OK I know there are a few threads about people who keep losing wifi connection even though their PCs/ other phones etc seem to work fine.
I had the same problem but I THINK I've found the solution. Only time will tell.
Firstly this was an intermittent problem. So why would it connect sometimes and not others. Simple answer. My Belkin router was changing to a different channel every time it was switched on. All you have to do is switch the router's settings from "auto" to a channel that you can make work. No more WIFI problem...........so far
