WIFI Problem
jamos316
First of I should tell you that I have 2 WIFI related apps installed on my ZTE Blade. They are: Y5 - Battery Saver (this app disables the WIFI connection when I move out of a WIFI area & also enables the WIFI connection when in a WIFI area) & Blade Wifi Fix (in the app description on 'Market' it tells you that there is a common problem with ZTE Blades in that the WIFI doesn't always come back on after wakes up from being locked or asleep, the app will always run in the background & if the WIFI jams it will simply fix it). I also have a app installed called 'No Lock' (which simply disables the lock screen). In 'Settings'>'Location & Security Settings'>'Set Up Screen Lock' I have 'None'.
My problem is when leave my phone for a time then I return & wake up the device the WIFI is not on, it usually comes back on in about 10 seconds auomatically. Is there something else I have to install to stop the WIFI from disabling ever. I want to be able to receive emails while my phone is sleeping as well as when it is active, also this affects my 'Whatsapp' app.
Go to menu>settings>wireless & networks>wifi settings then press menu>advanced and set your wifi sleep policy to none.
