wifi problem
i have micromax ninja A57
i am not able to connect to internat via wifi
whenever i connect then the status will show connected but when i open the browser or facebook
ERROR comes
when i open facebook the error is this:-
Sorry,login failed to reach facebook servers. please check
your network connection.(api.facebook.com[java.net.UnknownHostException])
can you suggest any sollution please.....???
Welcome anirudhsingh, glad to have you aboard!
Hopefully i can try and assist you with the issue you are having :)
First off is your device rooted/romed at all?
Otherwise have you tried doing a hard battery reboot, meaning, taking out the battery then putting it back in and turning and device on?
Lastly, have you tried a factory reset, mind you if you do this it will delete all of your data.
Hope one of these help! :)
