Help wifi problems after 4.24.651.1 ?
jj14x
Android Expert
Hi,
I have a unrooted EVO 4G that used to connect perfectly well to my wifi at home (802.11g) - even after the 2.3.3 update a few weeks ago.
I installed the latest OTA maintenance update (4.24.651.1) today and now, after I put the phone in standby (press the power button), and leave it for about 15-20 minutes, my wifi gets disconnected! The wifi toggle still shows that it is enabled, but when I go to wireless settings, it shows that it is no longer connected. Has anyone else noticed that?
I did restart the phone and also the wireless router, but it didn't resolve this issue. (other devices are connecting fine to this same router)
(Note: I did notice that my wifi sleep policy is currently set to 15 minutes - but I don't remember what it was earlier - I never changed it from the default)
I had the same thing happen...so I looked and the wifi sleep was enabled for 15 minutes. (I didn't change it). I changed it to never and things seem to be working fine now.
Try that.
I did the same last night - and yes, it worked too! Thanks :)
Do you recall if the default (before this last update) was "never"? or was it 15 minutes?
