Wifi problems please help
Brojak
Hi
earlier today i installed the MIUI mod and it is pretty awesome. Problem is when i try to connect to a WiFi network it gets stuck on obtaining ip address.
Any solution?
thanks
Well im guessing the "MIUI Mod" is a ROM. If it's causing you from being able to connect to a WiFi access point then its not worth it. I suggest you revert to whichever ROM you had before.
Ya but i know its possible to have wifi on this rom and i had to sacrifice all of my data and apps (nandroid didnt work properly) so i dont want it to be in vein 0_0'
