Since the 4.2.2 update I have been experiencing WiFi problems where it will work for days then suddenly say it can't connect to the internet. I can disable and re-enable WiFi and it briefly says connected then says no internet. If I go into work connection and click connect it says failed to connect. If I reboot it works normally again.
This has only started occurring after the update. Has anyone else experienced this?
