Help Wifi problems
deatbird
I have a Motorola Atrix 2 and downloaded thru the Motorola site. I have a problem where my phone continually loses the connection to WiFi and then I have to stop and reconnect. It is a pain Please I have tried all and it continues to occur. I even took the battery out for a day. Help
Does this happen everywhere or just with a particular WiFi access point (i.e. the one at your home)?
If it's just the one access point, and you have access to the router/AP settings... try going in there and disable Wireless MultiMedia extensions. It may be called WMM.
This completely solved a very similar problem for me.
