mill3rkydd
A few days ago, the available Wifi networks stopped showing every time I turned it on. Like a few minutes later, the Wifi would start, and but it took a while. What can I do to fix this???
Try flashing reppards kernel see if it fixes your wireless. Do nand backup first
Also Had issues with bobz. Narrowed it down to to networks using WEP.
I can connect to networks using WPA. Strange.
Also, couldn't get swype to work with this rom.
Dumped it
