can anyone help
all of a sudden my wifi connection has stoped working-its been absolutely fine i havent updated lately and was using it jsut a couple of days ago
the connection is fine off my router as im online right now on my mac
any help?
hi there
yes i updated but that was while ago now and i havent had any probs since till now-im a bit thick when it comes to the technical bit so how do change the address to make it static?
First up, connect to your desired network.
Settings -> Wireless & Networks -> WiFi Settings -> Menu (the button at the bottom of the handset) -> Advanced Settings -> Tick the box which says "Use Static IP".
You'll then need to enter the options specific to that network.
The screen should look like this -
If you're connected to a network, the IP address you're currently using will already be displayed (as it is in the top of the picture), enter that into the IP address pull down.
Your gateway will be the internal IP address of your networks router. You can get this by accessing a PC, going to the start menu, typing CMD and pressing enter. In the DOS window which opens, type ipconfig and press enter. You'll see a load of info displayed, you're looking for something called Default Gateway, take a note of that then enter it into Gateway section on the phone.
Netmask will always be 255.255.255.0
I think you can leave DNS blank as DNS should be handled by the default gateway.
The above may or may not fix the issue, but give it a shot and report back either way.
i have just seen the other thread sorry for the duplicate i have wifi analyzer it says -60 for strngth is that correct?
thanks again for your quick response
sorry to complicate further i dont have a pc im on a mac and have no idea where to start with that
i managed to find out all the correct addresses through my router server
thanks so much for your help its worked i shall go and thank el on the other thread aswell
thanks for your patience with me really appreciate it
and just to add i assume this wont work with any wifi just my own?
