What ROM are you using?Hey guys, so just yesterday I started having this issue with my nexus 5. No matter what I do I cannot get the WiFi to turn on. I haven't installed any new apps so I'm clueless as to what has caused this. Is there any way to get it to work? Thanks in advance!
And the xposed modules you have?I'm stock ROM. Rooted using Xposed framework.
Could be a kernel issue as well, are you on a custom kernel?
Op already factory reset, its not xposed ...How did you remove the xposed .did you flash the zip file or did you just remove the module . flash the zip and see if the WiFi return to normal if not . Flash the zip and then reflash the stock backup zip without wiping anything . this will keep your apps and data . .so flash the remove xposed zip first then flash your stock backup zip without doing any wiping .
