Wifi Tablet - Tethering Issues
Chippie86
Hi Guys.
I was wondering if anyone could help me with my problem. I have recently brought a new tablet (unbranded) which is running android 4.0.3 ICS.
I'm having problems getting my table to connect to the internet via the laptops ad-hoc network. From looking around, it seems that android devices do not recognise Ad-hoc networks, so is there anything I can do to over come this problem, without doing all this rooting etc?
My mobile phone (Vodafone 845) runs android 2.1, and I connect this to my laptop via USB to access the internet.
I did install connectify pro, and successfully set up a hotspot, my tablet connected right away, but it won't access the internet. The little signal bar in the right-hand bottom corner is grey and not blue which means no internet access from what I can make out, so I'm not sure what to try next.
Any ideas?
Thanks
Going to also bump this. :)
You could probable see what model it is if you go to Settings and there should be an option that tells you about your tablet. The more info the better. ;)
