donovanb09
i am using a smoked glass ROM on 2.0.1 droid. when i open the app everything is fine because im rooted but when i tap the wifi signal picture, it says please wait and then please check log for errors and when i do that it says
"Config WiFi Interface...
Error reading firmware image /system/
ect/wifi/Fw1251r1c.bin - Aborting...
Set property wlan.driver.status = failed -
ok
Failed"
and then this one too
"Loading wlan.ko module...
insmod: cant open'/system/lib/
modules/wlan.ko
failed"
Is there something I'm doing wrong because i think i might not have a compatible ROM or something, can you please help he out?
P.S can you wifi tether to an ipod touch from a droid?
ok
Failed"
modules/wlan.ko
failed"
