Root wifi tether for rooted precedent
Get the green wifi tether for root user it want get u in any trouble with your carrier and its made by the same guy
Download wifi for root users in play. Its yellow, not green.
(meuller, lemons, buxton)
https://play.google.com/store/apps/...S5nb29nbGVjb2RlLmFuZHJvaWQud2lmaS50ZXRoZXIiXQ..
open app
tap menu, settings, change device profile
select galaxy indulge
tap back
select change setup method
select soft tap (master)
reboot
it will not work unless you make these changes.
Check out the prevail forums for "wifi tether in infrastructure mode" he has a pretty good tut there also.
http://androidforums.com/galaxy-pre...ether-in-infrastructure-mode.html#post2931141
GIVE HIM THE THANKS AS IM MERELY SPREADING THE WORD.
Samsung captivate works too
R
This gets u into routing mode n u can connect 5 dwvices and now connect things like ps3 ect.
Green wifi teather is addhoc only
MY SOLUTION: Verizon Samsung Galaxy S3 Wifi Tether For Rooted Users Not Working
I rooted my newly purchased Verizon Samsung Galaxy S3 Jelly Bean 4.2.1 Stock today. Latest Wifi Tether For Root Users App failed repeatedly. Downloaded a prior TrevE Mod 3_3 found by Googling Wifi Tether and clicking the download link IN THE RESULTS SUMMARY
hxxp://code.google.com/p/android-wifi-tether/downloads/detail?name=wifi_tether_v3_3-pre1.apk&can=2&q=
Installed. Works perfect so far. Hope this helps someone.
