timkrisaaa
Okay so this program used to run great for me and I don't know
what happened. Recently, I can't enable wifi encryption or my
computer won't connect for some reason and the passowrd is correct
and everything so I have to turn off encryption to connect.
Now the newest problem is sometimes, more often than not, i'll
be browsing on the computer and all the sudden web pages will
stop loading but the computer and my phone both still show
tethering on and connected. What is weird about this is, I can
still go to facebook on my computer, that is the only website
it will load when it's acting up like this and I have no idea why.
So to get it working again, I go into settings on wifi tether
and change the channel to any other channel than what it's
currently on and it resets wifi tether and then I reset my wifi
on my computer and re-connect to the wifi tether connection and
then all web pages will load again until it acts up again
which can range anywhere from 10 minutes until it does it
again till sometimes it will work great for a couple hours
before it acts up and I have to reset everything to load web
pages, except like I said, facebook for some reason. So if
anybody can help me out as to why my computer will no longer
connect with encryption enabled and why out of the blue, it
just stops loading web pages unless I reset. Thanks so much
for any help!
for any help!
