Help Wifi tether problem on jellybean
Hi,
I am new in the forum, i hope i am doing right, i have tried to find answer to my question but without result, therefore please help :-)
Problem 1 ; Transmit SSID.
Problem 2 ; Bluetooth A2DP transmitting
Problem 1:
Problem with all jb roms i can find, they dont seems to be working with wifi tether transmitting >SSID< !
In all of the jb roms i have found and installed, (via .zip file,) it seems that the wifi tethering is turning on, but it will not transmit the SSID !
Is this a general issue or mabe my phone ? My wifi works perfectly.
I have also tried different tethering apps, with same result.
My stationary pc is on wifi, and i use it to scan for the SSID from the sgs2, but without result.
Please help.
Problem 2:
Problem with bluetooth sound. It connects, and i have checked that voice and music is check marked in settings for bt, but it does not sent the music to the bt speaker !? It sends the music to rhe external speaker (I can paus the music on via the bt sevice, so it is proper connected)
At this moment i use following;
Rooted SGS2
GT-I9100
Android 4.1.1
X-Treme cm10 beta
I9100XXLPQ
Kernel: 3.0.36 cm build 25 juli
version JR003H
