i use the experimental version have it like before lan0 i use encryption ..tick both driver reloads ..access control.. stay awake.. temp to f° lol.... works good.. using SuperSU and stericson busybox..if that mattersJust wondering if anyone knows the settings to get trevemod wifi tether working with kitkat or if i need to use another app to accomplish this. Thanks in advance
sometimes phone or pc won't find your hotspot i just cut off n on again .. usually fixesi use the experimental version have it like before lan0 i use encryption ..tick both driver reloads ..access control.. stay awake.. temp to f° lol.... works good.. using SuperSU and stericson busybox..if that matters
lol sad i never use my camera.. even though that camera in your quick settings tiles is pretty badass...anyone know y if i use that or voice record my phone reboots? only when i use from quicksettings pulldown tilesi thought it was the camera app too at first but i downloaded the google camera and it does the same exact thing
*EDIT* on the stock camera i found the white balance being on Auto caused the yellow tint problem
