hey does anyone know of a wifi tether that works my phone is rooted and i have s-off and everytime i use wifi tether for rooted users it says wifi interface failed??
Which ROM are you running? Did it come with your ROM or did you install it yourself?
There are like two things you need to do to that app to make it work. I can't remember exactly but I think you need to use generic ics wlan0 as the profile and enable access control perhaps?
If that doesn't work someone will be along shortly to help you out.
