Curtis1973
Android Expert
Okay. Need testers. I have decompiled and edited services.jar and have successfully enabled tethering,but on my other device I am attempting to allow net connection the device just sits there never loading the page even though it is successfully connected to mine via wifi tether. It may be my device or I may need to edit more to get things right. But I think I am on the right path. Testers be sure to back up your services.jar so you can copy it back to system-framework after testing this one.
I need feedback.
Are you experiencing the same issue as I am as noted above? Or something else entirely? Or are you connecting ok?
I think i either have it and am having device issues on the other end...may be a net issue,or I need to refine my mod...
file below....rename to services.jar.. copy to system\framework via recovery then reboot.
i may not be back on tonight but will check back in tomorrow morning to see if anyone has had the opportunity to test. will make any edits needed once i get some feedback or figure it is the mod it self.
I need feedback.
