Help Wifi trouble
NikkiC
My phone connects fine to wifi but as of recently, my phone won't load any apps that require internet or pages from the Internet using wifi. Just wondering if anyone else has had this problem or might know why my phone is doing this and how to fix it.
Thanks in advance.
Hey :)
When you say it wont load any apps that require internet, do you mean the app fails to load or the app loads but fails to show any data?
Have you tried manually assigning an IP on your Wifi network either that or double checking you are getting the correct IP in the first place...
Sorry for all the questions but one more...
Is this just one wifi network or all of them in different locations? have you tried to forget the network and re-connect to see if that helps
Hope that helps
Cheers
