If you have no 'mobile data plan' the major disadvantage is that you can't access the web, email, receive and send images, files, and video, etc. – in short: data traffic – when you're not connected via WiFi.
Yep thats pretty much it. You wont have access to data all the time, only when you are within range of a hotspot. You wont be able to use google maps on the go, or google navigation.
However, wifi is generally much faster than 3g, and uses less battery.
