wifi will not turn on
  • Start date Start date
A
Android Question
Guest
Hi. Have a s111 mini. WiFi worked ok, until i switched on save power mode.Wi Fi would not turn on. Since found out that this disables WiFi.Have cancelled this option,but will still not turn on. Message says turning on then goes back to Off. Tried going into Flight mode and then turning off. still no joy.Have also taken out the battery and then replacing. still nothing.Gone into advanced settings.keep WiFi on during sleep,and also turned off WiFi timer.Still no joy.
Please help(T Mobile)
Hi
Not sure what the problem is but power saving m mode does not disable wifi on my wife's s3 mini.
Tethering on would cause this behaviour but I'm sure you would have noticed!
Try rebooting your router - this sometimes works even if it appears to already work with other devices.
Roger
