Yeah..this update definitely BROKE something. I have never had problems getting onto my home wifi, but now when I boot the phone it will not automatically hop on my home wifi like it used to. I have to go into the wifi settings where it tells me that it could not connect. I have to tap the screen to connect, and then it will do it...but it should do it AUTOMATICALLY like it has for the last 13 months. I am NOT rooted, and am using the latest update. I JUST put the patch on, so I hope that it fixes it. I have the option to upgrade to the 3D, but I don't really want to spend the money if the bang for the buck is not there. Cmon Sprint/HTC....FIX these problems!!!
