Help WiFi wont connect to Vigor 2910
BartF
Hi all,
I just got my i7500 in today and I've been trying to get it hooked up on my wireless router, a Draytek Vigor 2910.
I've tried WEP and WPA/PSK, both won't work.
The WEP is trying and says "obtaining IP address from ..." for a while, but then it goes dead saying unsuccessfull. In my router I can see the phone connecting in the active list (the mac address shows while trying to connect), but than it disappears again.
The Draytek uses a 13 position WEP key.
Setting the phone to automatic doesn't work, nor does specifying WEP.
I also tried to use WPA. The Draytek is now set to WEP or WPA/PSK (Mixed WPA + WPA2) with a 8 position WPA PSK.
My i7500 shows the connection as WPA2, but it won't even try to connect. According to some FAQ I also need the setting TKIP, but I can not choose that on the i7500.
Did any of you have the same problem, or even better ... know how to solve this ?
MvG,
Bart
Hi all,
MvG,
Bart
Hi Bart,
I can tell you that so far I had no issues whatsoever with my Galaxy i7500, I'm connected with my D-Link wireless router using WPA2-PSK(Wi-Fi Protected Access 2 with Pre-Shared Key) in mixed mode g/n.
Try to do a hard reset.
Hi all,
it seems it might have been a problem useng WEP and WPA together. I set my router to WPA2 only and now it's working fine. I just had to reconfigure all my wireless devices.
MfG,
Bart
