Help Wifi wont turn off
djle9
Samsung Note 4
Even though I turn off wifi, in the battery usage section, it shows the wifi is turned on the whole time of the battery cycle. The only time it goes off is when I change to airplane mode.
I can not figure out why it wont turn off for longer battery life.
Any suggestions would be appreciated. Thank you for your time.
for extra clarification. When I do toggle off wifi, I cant not use it. Its just shows up in the battery usage section so I assume its eating battery life.
I understood the battery usage shows what you have used, not what is being used at the present time, so even though you switched off the Wi-Fi it will still report the amount of battery it used while it was switched on. Phil
what i see in the battery usage in the history details is a timeline of what is being used and when. The wifi is a solid bar indicating that it is being used the whole time even when the phone is sleeping and wifi is turned off.
