XVirus
Hi,
I was using cyanpop rom for a month now when suddenly my phone crashed. I restarted it but it was in a bootloop. So I did a clean flash of the rom and the rom worked. But if I tried to activate the wifi, it just shows "wifi turning on". I clean-flashed 2 other roms with the same result. So I deleted everything and restored stock Android 5.0.2 rom(
Now if I want to activate the wifi(through settings) the switch button goes on and then it goes immediately off again. I tried de/reactivating airplane mode, I did a hard reset 2 times, I deleted cache...
What should I do?
By the way if I go to the status settings it shows: "WLAN MAC-Adress: " unavaiable
Code:
adb reboot bootloader
mfastboot.exe flash partition gpt.bin
mfastboot.exe flash motoboot motoboot.img
mfastboot.exe flash logo logo.bin
mfastboot.exe flash boot boot.img
mfastboot.exe flash recovery recovery.img
mfastboot.exe flash system system.img_sparsechunk.0
mfastboot.exe flash system system.img_sparsechunk.1
mfastboot.exe flash system system.img_sparsechunk.2
mfastboot.exe flash system system.img_sparsechunk.3
mfastboot.exe flash system system.img_sparsechunk.4
mfastboot.exe flash modem NON-HLOS.bin
mfastboot.exe erase modemst1
mfastboot.exe erase modemst2
mfastboot.exe flash fsg fsg.mbn
mfastboot.exe erase cache
mfastboot.exe erase userdata
mfastboot.exe reboot
What should I do?
