Wifi
I leave it on and it flips between the two, prioritising my remembered WiFi connections over mobile network.
At home I leave mine on all the time. If i'm on the road I turn it off and if I need net access, I turn on the 4G, unless I think there may be wifi access available.
I guess it does drain the battery if you leave it on and it's 'Searching'.
I'll have to give the Y5 a try. I like the idea of it turning itself off.
If you are connected to some hotspot with Wifi on all the time, the battery drain is minimium.
My phone loses 2% of charge overnight, while sitting in my table, during my sleep. (around 8hrs/night)
