Wifi
I have a problem connecting to my home Wifi. It says saved then searching then saved and finally it says there was an authentication problem. I have reset the router and entered the factory password so I'm not sure what's up. I would like to use Wifi so any help is appreciated.
Not certain I can help but I can suggest a few things I recently had problems with my wifi connecting, but I had my home wifi setup as static which after talking with a rep who was no help said that was ok, but have you used your wifi with another phone? Could some of the advanced settings be off? Keep wifi on during sleep should be always...proxy settings, IP settings I think for normal connection is DHCP. Try checking those if you havent already...hopefully it helps
