hi why cant i use my wifi at home? ive been trying to log in since this afternoon and all it says is that the connection is slow, and i could connect to wifi's that dont have passwords only?
"Forget" all the existing connections and log into them as new connections.
Android identifies a wifi connection by its name (SSID), If you logged into a non-secured network named linksys, and the one you have at home is named linksys but it's secured, the phone things it's logging into the old non-secured one and won't connect. "Forgetting" the old ones makes it treat all the connections as new ones, and it'll ask for the password if one is needed.
