Wifi
  • Start date Start date
Hello. Go into your settings and turn on use available wifi or something similar. It should then be in a seek mode. It should bring you a list of available wifi connections. If you have wifi at home.. your router by name should be in the list. If you have it secured by a password you will need to input that password once you click on using that connection. It will remember the password so you will only have to do this once. I hope this helps.
