plutoniandroid
Is 2.3 expected to allow us to download apps to the sd card instead of internal memory? It is very annoying to have to constantly delete apps to put on new ones.
adb devices
adb shell pm setInstallLocation 2
adb shell setInstallLocation 0
You can already do that with 2.2 as long as the developer allows it.
If you want to move more apps to the SD card, you'll need to have the Android SDK installed. How-To Install Android SDK On Windows, Mac and Linux
Then on your phone go to settings>applications>development and enable USB Debugging. Plug your phone into the PC using the USB cable.
open a command prompt on your PC (start>run type "cmd" press ENTER)
Change directory to the android-sdk-windows\tools folder
At the prompt typeand you should see your phone listed as a serial number.Code:adb devices
typeCode:adb shell pm setInstallLocation 2
Done.
Now the default location to install apps is the SD card. And, some apps that you couldn't move to the SD card will now be able to be moved. Keep in mind Widgets and services should always be installed to the phone and not the SD card, so if you follow the steps above and you install a widget afterwards, you will need to go to settings>applications>manage applications and manually move it to the phone. If you want to set the default install location back to the phone, you simply repeat the process but useCode:adb shell setInstallLocation 0
Hi,
followed the instructions, but after I confirmed adb shell setInstallLocation 2, nothing happened - no message confirming anything. Then I tried downloading a really big app (20MB). I had only 15MB free space on my internal memory but SD card had plenty of free space. But, I got "Not enough space to install this app" message. (its Abbyy Business Card Reader Lite)
Any help please?
Thanks for the reply.
So it would be clever to have at least 40MB of free internal space in order to download and temp-install large apps that then they would get moved to SD automatically. Is that correct?
Dear Lunatic Sir,
I have done it till going to the tools folder in cmd. But after that when I typed "adb devices"
and pressed enter. Its showing "adb is not a recognized internal or external command".
Please can you help me sir in this case. Please!!!
Thank You
I downloaded and installed the Android SKD, as well as the Android 2.3.3 (API 10); my Nexus One is 2.3.6.
I can run adb, but adb devices doesn't show any phones. I didn set USB debugging to ON.
Any idea why I can't see the phone?
thanks,
...Rich
Done.
adb.exe
AdbWinApi.dll
AdbWinUsbApi.dll
