new uncharged battery? there is no such thing......wait.....i see what you are trying to say. yes a new battery is charged to full upon initial assembly, but will not be charged again until sold.....so technically they are all charged, just not re-charged......just say new battery, it is understood that the new battery has not been re-charged.I want to replace the battery on my LG K20 phone with a new, uncharged battery. Will the data (contacts etc.) be lost during the transition and new battery charging?
oh yes a removable battery will not mess with data. internal storage is separated into partitions. one partition is where the android os lies. there is also a partition for your data as well. so even when there is no power, your data stored in that partition will be saved. i have switched many batteries on my android phones before they went with non-removable ones and i have never lost and data by doing so.I understand your point that the new battery was initially charged and it has since lost that charge. The LG K20 has a replaceable battery so it's a relatively simple matter for me to remove the old one and put in the new one. My question comes down to how is any data (contacts et al) maintained for the half-minute or so while the battery replacement is happening (no battery at all) and the subsequent time it will take to charge the new battery?
So for your own sake, start backing up your phone's user account. Backups are important. They really are. Especially when you send your phone off somewhere to be serviced by a stranger. And be sure you've set up a lock screen.
Screen shot the phone and number, and then move them to terabox (cloud service), and that way the numbers will be safe and soundPictures are all copied to my computer. As for contacts, do you have a recommendation for a non-google backup software/method?
no need for a screenshot of your contacts. just make sure that your contacts are under google. when the account gets sync'd, your contacts will be saved.it's not Huawei - it's LG.
And far too many contact numbers for screenshot.
