Will hardware keyboard work on Trio Stealth tablet?
  • Start date Start date
A
Android Question
Guest
Will a generic hardware keyboard work on Trio Stealth tablet? I just bought a keyboard and when I received it, it has no markings or a brand, it came with usb, will it work on my Trio Stealth G 2 tablet and will I need to find and install a driver for the keyboard? Specs:
10.1 Capacitive touch screen
Android OS4.1 Jelly Bean
Dual Core processor
Thank you
Poncho
Since the tab runs Jelly Bean, I assume it's capable of OTG, so you'll need an OTG cable (you can buy them on Amazon for about $2 if you don't want to make one). Plug the keyboard into the OTG cable and the OTG cable into the tablet and you should be good to go.
